hello everyone, after my ignition system being immobilized on my 2003 monster 620 ie. i decided on looking for a new system. i found a good deal on a system from a 2008 monster s2r with ecu + guages+ locks and black and red key!! would this be compatible with my 2003 m620? *crosses fingers*
correction : 2003 ducati monster 620 ie. ignition system to 2008 monster s2r ignition system.
This is what I know:
Keys + Gauges = YES, no need to swap ECU[see below]
ECU = NO [S2R=1000 Dual Spark; 620ie=620, different engines and needs]
Keys can be programmed to gauges and "OLD" ECU... So I've been informed by Ducati techs and the forums tech threads...Will you get the Ducati Code Card with the purchase?
The code card will not be included. If the old ecu is immobilized this new purchase is for nothing?
So if I get it right, you lost your red key and code card? OK, then do the following, reflash the ECU so that the inmobilizer function is de-activated and voila, no more inmobilizer[cannot do it to mine, it seems my ECU is not within 'reflashing parameters].
This my friend, if I read correctly, is the only other option you have other than buying new, DASH and KEYS....ECU can stay put...
