front fork adjusters
the standard positions are as follows, from fully closed position:
compression 12 clicks
rebound 10 clicks
spring preload 19 mm. ( is not posible, here is the
problem)
shock absorber adjusters
starting with the adjusters totated fully clockwise,
turn adjuster (1) 10 clicks
turn adjuster (2) 12 clicks
spring preload: 11 mm ( is it correct ????)
thanks.
Discussion Starter #2
solution:
the standard positions are:
compression 12 clicks ( from right to left )
rebound 10 clicks ( from right to left )
spring preload 11 turn (from left to right)
