The Max Biaggi Replica Spec 1R Extreme Helmet from Suomy combines ancient Roman themes with modern safety. DOT and ECE approved, this helmet is light and comfortable with Suomy’s trademark Alcantara interior. This fully removable liner is soft yet wicks moisture away and keeps your head cool thanks to the integrated ventilation system that works with the helmet’s shell to deliver outside air directly to your scalp. To further aid this cooling effect, the helmet comes with an anti-IR faceshield out of the box to defeat sunlight’s warming effect. There are also a wide range of visors to choose from when ordering.
Call TJ at 866.931.6644 ext 817 to get one of these lids sent to you fast! If you’re new to the Suomy line or unsure of sizing, just let TJ know exactly what you currently wear for expert size guidance. You can also email us: send those to FORUM at RIDERSDISCOUNT dot COM with SUOMY BIAGGI in the subject line and we’ll get back to you right away.
