Suomy Spec 1R helmets are one of the lightest models on the market today. But just because they’re light, doesn’t mean they’re unsafe. In fact, their advanced Structurally Enhanced Composite Fiber Weave (S.E.C.) design insures the Spec 1R passes what Suomy argues is the most stringent modern helmet safety standard – the British BSI 6658. It’s also DOT-approved. Helmet safety standards aside, a lighter helmet can be expected to manage impact forces better than a heavier helmet of a similar design. Then there’s the graphics – another area in which Suomy excels – the Gadea is no exception; all graphics are flawlessly rendered on the outer shell. Just as beautiful, though less visible, is the helmet’s Turinda anti-microbial liner. This liner is fully removable and is designed to resist the growth of odor-causing bacteria. Available in sizes X-small to XXX-large, there’s a Spec 1R that’ll fit your head.
Call MIKE at 866.931.6644 ext 804 to get one of these lids sent to you fast! If you’re new to the Suomy line or unsure of sizing, just let us know exactly what you currently wear for expert size guidance. You can also email us: send those to MIKE at RIDERSDISCOUNT dot COM with SUOMY GADEA in the subject line and we’ll get back to you right away.
Don’t forget to ask for a dark visor when ordering!
