Discussion Starter · #2 ·
I got info from Italian friends for SD154 Ohlins damper for S4 and it should go well on M1000.
Instructions from www.ohlins.com
Any SD154 users out there ? Price ?
Skier
I have a SD154 on my M1000. Got it for around $400.
One glitch, so to speak, is the bracket that attaches to the frame doesn't fit the bottom frame tube. It would look nicer on the bike if the damper could be set parallel to the bottom frame tube (like the pre 02 Monsters I've seen).
Herb has the same setup. Check it out in the gallery section.
Thanks Jiro !
Good info.
I will go to WDW without damper, let see if there is some promotions ,,,,
I also added the Thread that I found to first post.
Keep them ideas and comments coming in.
Or is this stuff already covered somewhere like FAQ ?
If so, do not call me bad names....
Skier
