Well, after the short lived euphoria, thinking I had solved the starting problems, I am back on with the investigations as the following day, the bike once again would not start. So this time I checked and cleaned the the fuses, plug leads, plugs and relays. And now once again, the bike is behaving itself and starting. I think it was probably the starter relay because when I turned the ignition key to start the motor previously, there was no audible click from the relay. I then tried the age old method of tapping the relay with a screw driver, and sure enough the click was back and the bike started, and has continued to do so. So my question is, should I now invest in a new set of relays to eliminate the problem in future. Secondly, I have a strong smell of fuel which I'm sure should not be there, so what could that be due to, or is it nothing to worry about? Thanks in advance for your replies.
