1 - 20 of 29 Posts
I haven't started the bike in a few weeks and last night decided to fire it up. All the lights come on with the ignition, but when I press the start button, it just clicks. It was clicking rapidly at first, then was clicking slower. It finally fired up for about three seconds and died. Anywhere I should start looking? Thanks.
Crazy...I was about to take off just 20 minutes ago and experienced the exact same issue with my Monster 750ie 2002. I rode the bike 1 week ago so I'm gonna go back to the garage extract the battery and charge it. We'll see from there if it's issue; I charged it few months ago but it's the stock battery so it's 7 yrs old...hope it's as simple as that.
I would assume yes, lights and electronics shouldn't require as much power as the starter does, that's just a guess though. Ok I'm charging the battery so I'll be able to try in a few hours. I don't know why all of a sudden something would fail on 1st start like that (relays, solenoid...). We seem to have the same background of letting the bike stands still for weeks.
Sounds like the battery for sure. When my bike is not in use I always keep it on a battery tender. With bike batteries being so small it dosent take to long to lose charge.
all right the bikes starts fine!
Now the battery has definitely run its course, I just noticed some white green build up on the negative lead/connector (corrosion...leak?) so I'm gonna shop around for a new one asap.
Sounds like you have the same battery issue, get a battery tender and charge it; maybe you should get a new one if yours is stock also.
You both might want to get a multi meter and check the battery while running to make sure it is charging.
I had same issue, voltage regulator took a crap on me.
Interesting...what kind of value am I suppose to read/expect?
Is the voltage regulator that thing below the seat? It's stock and I don't know
if it's worth changing for now. Anyway I just ordered a Yuasa so that's one upgrade already.
Yes, the VR is that square thing under the seat. It idle, I am getting 13.3, at 2,500 I am getting 14.6 to 14.8
If you are at 12.8 or below on a fully charged battery, you are just running on the battery, which will suck dry.
Discussion Starter · #14 ·
Ok, it's running again! I let it trickle charge for a few hours and it started up with a little difficulty. It is low on fuel, so that probably didn't help any. I'll check the battery for the voltage next. I hope the VR isn't bad. Thanks for the help.
so does that means the vr is necessarily faulty/failing?
Generall speaking, yes, it you aren't getting over 14.5 volts at 2,500 to VR is on the way out. OF course, it could be the stator too, but n 99.5% of the cases it is the VR.
I figure that if I can charge the batter up on a tender, and then unplug it, and it will hold that charge, the battery is OK, If I then fire the bike, but don't see the voltage increase, I have a problem.
I just received the Yuasa and charging it, will install tomorrow. Got a good deal @ $100 online.
Is there an aftermarket VR available?
Tripod I have found that the best way to keep the battery fresh is to leave it hooked to the bike and on a battery tender. It keeps the battery fresh and if you want to ride all you have to do is unhook the tender and away you go.
1 - 20 of 29 Posts
