I do, and would be happy to tell you, but are you sure it needs to come out? It's a PITA.
well the problem is I found out a few parts of the starter Magnet parts and such i also accidently broke the terminal of so I think I need a new starter unless I can repair it I have no idea what a good starter and bad one is.
Well in that case. There are two screws that are removed from the outside on the flange of the starter.
The third one has to be removed from inside the left side cover. You need to make a cover removal tool. There are a bunch of threads on how. The third bolt is behind the idler gear between the starter and flywheel. Some engines have a hole in the gear to access the bolt.
