I Need some help... I have a 1999 750. The battery didn't have the juice to turn it over. After a re-charge, I reconnected the battery and the starter motor started... even with the key in the off position. Someone told me that low current could cause the starter selonoid to stick. So I got a new battery. The problem seem to go away until last night. After a ride, I turned the key to the off position and the starter started cranking again... If I turn the key to the on position it starts and runs fine. Turn the key off or hit the kill switch anf the starter cranked away?? The only thing that stopped it was disconnecting the battery cable. Anyone have some advice?
