On my 03' 800ie I changed the brake light on my rear and then tried to restart the bike.
Checked all fuses, were okay. Reprogrammed immobilizer thru sequence suggested with all 3 keys (1 red; 2 black).
When turn switch on; lights come on, dials show correct readings; battery is strong, fuel pump comes on, No Ignition!!? Any ideas?
Thanks,
Fergie
Thanks,
Fergie
Is it cranking over? Don't overlook the obvious - check your kill switch.
Start up
Yes have checked kill switch.
Does the immobilizer require me to have my code card # to re program? I used a method that only required the 3 keys??????????
After the key is on do you get any flashes on the small amber led on the dash, does it stay on solid after? Try to use the throttle imput immobilizer code that is on the code card.
