Would a wheel from an ST2 or 4 fit on a '03 M620?
I'm not sure about the year of the donor bike/wheel.
Do they use the same diameter axel?
Discussion Starter · #2 ·
yup.
both front & rear rims are swappable between the following:
2001-2002 monster s4
2002+ monsters (all but the s4r of course)
st2/st3/st4/st4s/st4s-abs
swingarms as well for that matter. if you happen upon an aluminum take-off from an ms4/st4/st4s/st4s-abs, it's a bolt-on upgrade compared to your stock steel unit.
Thanks for the info.
So if I understand correctly the model year of the ST does not matter?
The 1998 ST2 has the larger axle, so I would expect that they all do. Definitely not a straight swap with the 1997 Monster front wheel.
