I need to replace the front and rear sprocket and I need to know what I should order. I like the stock set up as I mostly tour and commute, but any suggestions and considerations are appreciated. Thanks in advance.
Drop a tooth in the front. Easy, cheap, and you'll love it.
If I had to buy a new set, I would stick with a 15-tooth front and make the gearing adjustments at the rear. You're one of the few people I've heard of that likes the stock gearing. I would add two teeth at the rear if it were me.
How many sprocket threads can we get going at once?
;D
