Due to the oil galley plug, I have to. :'(
Any rookie mistakes to avoid?
Which bearings should I replace?
Crankshaft, gearbox (all 4) & cam rod bearings enough?
Connecting rod bushings, leave if within specs or replace?
Any bushings, oil seals, bearings etc I should just leave after checking because
"If it works, don`t fix it!"?
Any tips & tricks appreciated!
