· Registered
I noticed earlier that there are spacers under the screws that fix the right-hand peg mount bracket.
· Premium Member
When I took the spacers off of my right side pegs after removing the charcoal canister, I noticed that there were also spacers on the left side where the front 2 screw holes are. I only noticed that because I also found the screws to be too long when i tried to remove them. So I added the front 2 spacers back and everything seems fine...
· Registered
Don,
you care to part with those spacers?
I'm removing the center stand that the PO had installed. I noticed that part of the stand mount goes in where there seem to previously have been spacers. So I need a couple.
My bike is a '99 and so the evap cannister was under the seat, not on the side. So my spacers must be there for another reason.
Anyway, can I get a couple off of you (or someone who has pulled the stock sets for aftermarket rear sets)?
