Seacoast sport cycles bike packages
Performance Package - **New**
Model Years: 04-07 RSVR & Tuono (other applications available upon request) Arrow 2-into-2 Exhaust (either Titanium or Carbon Fiber cans), Evoluzione Airbox and Performance Air Filter, Evoluzione Fuel Pressure Modifier, Dynojet PowerCommander III USB, Professional tuning by a Dynojet Tuninglink certified technician. This will yield an approximiate increase of 10-horsepower. Recommended for either street or track use.
$ 2,995.00 (complete bike)
Stage 1 Motor Kit - **Revised and Improved**
Based on our proven SSC Piston Kit, this is available only as a motor upgrade package and includes: 100mm Pistions, 100mm rings, New Head Gaskets, New Oil Filter, New Cylinder Gaskets, Bore and Replate the Cylinders and Professional Disassembly, Installation and Reassembly. The parts and tuning will increase your horsepower by approximately 10-horsepower. Recommended for use with our Performance Package. Suitable for Street or Track Use. (Model Years: 04-07 RSVR & Tuono other applications available upon request)
$ 1,845.00 (motor only)
$ 2,545.00 (complete bike)
Stage 2 Motor Kit - **Revised and Improved**
Includes everything in our Stage 1 Motor Kit PLUS: stage 3 porting of heads, radius valve job, slotted cam sprockets, optimized cam timing and Professional Disassembly, Installation and Reassembly. This will increase your horsepower by approximately 16-horsepower. Suitable for Street or Track Use. (Model Years: 04-07 RSVR & Tuono other applications available upon request)
$ 3,195.00 ( motor only)
$ 3,895.00 (complete bike)
Putting it all Together and add some more to get the Ultimate!!!
Everything included in our Performance Package plus our Stage 2 Motor Kit with a custom map for each cylinder, new exhaust cams and lightened flywheel, along with Professional Disassembly, Installation and Reassembly. Approximately 20+ horsepower. (Model Years: 04-07 RSVR & Tuono other applications available upon request)
$ 7,895.00 (complete bike)
I believe the Ducati is covered under the "(other applications available upon request)"
Seems nice, but awefully pricey.
"other applications" wouldn't necessarily have the same specs (cam timing, bore size, horsepower gain, etc.)
the guy is a fully certified Ducati and DynoJet mechanic. I just think the custom map for each cylinder is insane.
AFAIK, all of the S4 and '02 and later Monsters effectively have different maps for each cylinder ( one map, and one 'offset' table, but that *is* two maps).
