Whle "pre flighting " my S4 for a bit of a trip tomorrow, I discovered another place that small stones build up. The point where the rear suspension attachs to the swing arm creates a small well ideal for holding small stones. This is a pivot point and I would think possibly it could impinge on the movement when full of stones/gravel (as mine was).
They are not that easy to get out of there (I used a small screw driver to flick them out).
Still got your hugger on?
Shop vacuum can work well too.
I've had to fish a nut and bolt out of there a time or two that I fumbled.
+1 shop vac,
or, if you don't smoke,
a lungfull.
I find that if I use a wax spray when clean,
less detritus will build up in those spots (changes their adhesion-tension) yes, I made up that word.
I still have a hugger on although its a bit of a shorter one due to a mod I made to it because of an accident caused by another mod I made :-X
Also, check the 'dishes' in the top of the lower triple clamp. I got a stone wedged in front of the lock stop screw. I could turn the handlebar one way at all. It was locked straight ahead.
I nearly fell off. I think it must of got deposited there from my bike cover when I removed it. Took about an hour for the stone to work its way down through the instrument cluster to its final destination. I had just come off the freeway when I discovered it. It scared the **** out of me.
Why the lower triple clamp casting has a nice dish shape to collect crap defies me. On Jpn bikes the screws are under the triple clamp.
Canned air that we use to blow the dust bunnies out of computers. Cheap and portable.
