had on my s4 a new clutch fitted and it slips is it just a small adjustment??? or des it have to come a part again and be refitted any help would be appreciated thanks
check first that the pressure plate was fitted correctly.
there is a notch on the plate that lines up with a hub post with a groove on it.
otherwise it doesnt click down all the way
jeff h
monsterparts.com
and for that matter, if you got one from YoYodyne, check that they put that mark in the correct place. Mine was off.
