1 - 8 of 8 Posts
My S4 does not stay running on the side stand due to the electrics preventing it.
Is there a way to change this to the "normal way" as all other bikes have.
I would like to have it that when you select first gear the engine will die when side stand is out.
Can anybody help?
If you don;t want to spend $30 or more for the kit, you could also do it yourself with a $2 diode and some wire. I did it on my 996 and monster with great results.
seen the same plug in and forget (or similar) kit on eBay a number of times as well. Just for thse looking for the same thing who are not technically minded enough to jerry rig their own.
I bought from TPO the bypass kit but it does not work. If all connected the engine does not start at all. As soon as I change the plugs again it does start.
Can anybodu help me a wiring diagram for how it suppose to be connected as I think that the plug to the side stand switch is not connected right inside.
1 - 8 of 8 Posts
