I actually have two questions I need help with, the first is an easy one.
I need a new tail light bulb and I wonder if I can find one at an auto parts store or will only OEM work?
Second question, anybody got any tricks for getting the bolt that holds the side stand on, out? It is a very shallow allen hole that is already stripped out from the previous owner trying to get it tight and not realizing that the play was not from the bolt. I tried using a hand impact driver (the kind you hit with a hammer) and I soaked it in WD-40 but still no luck. I may have to grind a notch in it and chizzle it out.
Actually I have a third question, does anyone know if I will be able to use a generic bolt to replace it? Im sure Ill be waiting forever if I have to buy it from Ducati.
Thanks for any help
Thanks for any help
