1 - 8 of 8 Posts
Hello.. I was reading up on some backfiring threads. I saw some similar problems but no post as to what the problem was.
Wanted to know if backfiring is common on a S2R 2005?
I noticed some minor backfiring just before the 600 mile service. Now I'm arround 3200 miles and its started again. I have not changed any parts that would change fuel or air flow. (Stock exhaust and air box/filter) Backfiring occurs when I throttle down. Man it's loud! My friend was riding behind me and said he could feel the compression hit him. We were moving around 50 + mph
I called my dealer they said they would treat it as a warranty, unless its the CO. They said the would charge me for 1 hr. 75 US big ones to set the CO.
thanks for any help you may provide,
Kevin
Backfiring "typically" signifies a lean condition. Most Ducatis run slightly lean right out of the factory. However, it should not be backfiring, especially if you have a bone stock bike.
Mine backfired when I installed cored exhausts but it went away after I installed my new system and adjusted the air/fuel trim.
You might examine your spark plugs.
And have the dealer examine the bike as well.
PS: This thread probably belongs in the "Tech" section.  ;)
Mike
Yep must me lean. Sounds strange becasue I'm running the cat eliminator and cored cans and I haven't had any backfiring - with no trimming... I keep a close eye on my plugs and so far they are light toasty brown.
+1 on leaks.  If you have previously removed your exhaust and put it back on chances are the disc gaskets are no longer working properly and you may need to replace them.  I had the backfiring problem with mine after I switched to a full Arrow system.  Once I changed the gaskets the problem went away.
Item # 33
I am going to be installing my Cat Eliminator pipe and Termi's on my 05 S2R real soon, and in addition to using new gaskets I am also going to use some high temp RTV sealant. No leaks!!
Phil
1 - 8 of 8 Posts
