I have Ducati Service manual for ’06 S2r1000. According to the manual front sprocket should be supported by retaining plate with two bolts. When I took off front sprocket cover, all I can see is a single 32mm nut (see attached image)? Did anyone encounter this problem? If so is this nut the only thing that supports the sprocket if so what’s the torque required? Also, note that the washer under the nut is bended and a small yellow mark is made on both the nut and washer. Is this the indication to see if the nut is slipping? Any idea why there is service manual discrepancy? Since this is model/year specific one it should be dead on!
