Ok, sorry for the late reply (I fell asleep after work
but I think I've figured out what's going on, did you take the fuel tank off yet? I'm guessing you haven't.
If you take the tank off (open the seat latch, take the seat off the hinges and disconnect rear lights, remove the 5mm hex head bolt holding the tank on, pull back on the tank, then you should be able to rotate it 90 degrees so you can see the airbox underneath, remove the air filter if there's a full one there), where the side vents enter the airbox, you'll find two spring clips that hold the side vents in place.
You've already removed the front bolt as that's what partially holds the front fairing in place, so if you've removed the fairing, the spring clips should be the only things left to remove other than the signals.
Let me know if that helps any and if you get stuck again, just post up here [thumbsup]
