Did you know the stock license plate brackets and bolts on late model Monsters weigh in at 440+ grams! I didn't until I took them off and weighed them. I've seen heaps of "performance parts" for hundreds of dollars that can't reduce weight by 440 grams.
A lot of the "tail chops" I've seen remove the curved duck tail. I think that looks OK on late model Monsters but the OEM license plate bracket is another story. It's big, bulky and ugly and it just has to go. (What were Ducati thinking?)
The photo above shows my MY03 M1000Sie with the offending item. Not even the cool, cut-down Strati-pipes (http://www.ducatipipemod.com/) can redeem the rear-end!
After a bit of web crawling I was just about to part with $20 for a straight piece of bar with three holes and a bolt, also known as License Plate Relocator. While this may be a quality part, I never know for sure if it will fit "my model".
Then I saw someone on DML (sorry, can't remember the name) post a picture of a home made bracket. It looked simple enough but the picture only showed it post-instal. It was hard to see exactly what the guy had fabricated to do the job.
So I decided to have a crack and here's what I came up with...
** My License Plate Bracket Mk. I **
The bars are each 33cm long and bent and drilled identically.
The parts are unfinished and look a bit rough but they are virtually invisible on the bike when installed so I may not even paint them. We'll see.
Total cost: About $2 for the cheap alloy bar (1 metre) from the local hardware mega-store.
Tools: Hack saw, drill, vice, ruler, marker, sparkies tape.
I simply bent the 2 alloy bars by fixing them in a vice, side by side, and pressing down on them with a long piece of steen bar. Voila, identical bends on both sides. Too easy.
Time to prepare: About two hours for a first timer.
The total weight of the parts removed was 440 grams. I reused half the original nuts anb bolts. The only new material was the alloy bar and that came to 125 grams.
Net weight saving: 315 grams - 11.25 ounces in medieval measures.
And the end result doesn't look too bad at all....
I kept the rear reflector on as it is a local traffic law requirement. But it is tucked up nice and snug now and looks pretty neat.
I'm not real good with my hands (read computer worker) so I have no doubt anyone else could do as good if not better than I did straight up. So don't be afraid to have a go yourself.
Tip: Part of the plastic I removed, under the seat, acts as a weather shield for the tail light and wiring. I wrapped a bit of sparkies tape around some wire and connectors to ensure everything stays dry in future.
Cheers, Dean (M1000-DS)
