1 - 8 of 8 Posts
Question came up this morning: If you are looking at replacing the stock wheels with cast or forged magnesium wheels, should you go with exactly the same width as stock (5.5" on my S4), or is there any complelling reason to go to, or NOT go to, a wider wheel?
Being a novice on wheels, it occurs to me that a wider wheel might theoretically improve traction a bit (maybe?), but would also weigh more, be a little more resistant in handling response, might potentially come close to hitting other parts in its proximity (e.g. the rear brake hydraulic line), and might require a different tire (wider) which adds more weight yet and more cost.
What do the mod experts say?
Jim G
S
wider rim = pimpin
stock width rim = better handling
you'll need a wider rim for a wider rear tire if you're stomping out big power. by big power, i mean more power than your s4's capable of after $5k of engine tuning.
remember that a wider rim/tire is heavier -> more gyroscopic effect -> slower turn-in.
You ccould easily fit a 180 or 190 rear tire on a 5.5" rim, which would look very fat from behind. I don't see a reason to go bigger on a sport bike type setup...
Discussion Starter #5
Sliver: Is that tire mounted on a STOCK wheel???
It didn't HIT anything else on the bike??
Jim G
S
Ground up build with a custom wheel and frame. 250 tire looks cool but doesn't handle fot sh!t!
Jim,
I purchased forged Magnesium rims for my bike and stayed with the stock size on the rear. I feel as though the engineers are way smarter than me and the put a 5.5" on it for a reason. Also, a 5.5 is optimal for a 180 tire, and its gotta weigh at least a tiny bit less than the 5.75 or 6"
Just my $.02
Jeff
Hey sliver,
Is that an R60/2 that I see lurking in the shadows?
1 - 8 of 8 Posts
