1 - 10 of 10 Posts
I don't get to ride that often, but I love it. Looking to upgrade to a 750 or 800 Monster from an '86 Yamaha Radian. Wondering if the fuel injected Monsters (2002 0r 2003) handle "sitting" better than say a 2001 750 carberd Monster. Are carbs getting mucked up over time the major problem? I hated paying to have the carbs cleaned on my Radian. Is Fuel Injection more tolerant of sitting? Is a Ducati Monster even a good choice for a bike that will not be used for some long stretches? Any tips, advice, opinions are greatly appreciated.
I have been riding for about six years, just not putting a lot of miles on my current bike. I love the Monsters and hope to find the time and inspiration to ride a lot more if (hopefully, when) I get a Monster.
Re: Sacrilege: a Monster that doesn't get ridden o
Advice I heard from everyone when deciding to get my monster was to go fuel injected, and that the carbed bikes tend to need more TLC. Just what I heard, that's all.
Oh don't worry; once you get your Monster you WILL be riding more - allot more. ;D
jb
Jim, don't you know what happens when you ASSUME?
When you get your monster, you will probably find yourself riding more.
As for sitting .. how long are we talking about?
You may want to put a trickle charger on your battery if you let it sit for extended periods.
another thing for a stored bike (i'd guess you've been doing this with the radian?) is to top up the gas tank at the end of every ride to minimize condensation -> rust in the tank. and when you fill up, pour in a bit of stabil with the as AT THE STATION so that it circulates through the tank -> lines -> injectors by the time you get home and pack 'er away.
What Strati said.
Rolling into the garage and pouring a bit of Stabil into the tank won't do d!ck for you. The primary gumming problem is in the jets (for a carby) or injectors (for FI), so you have to get the Stabil to that point in the fuel system for it to really help you. That can take a while.
Last winter when I pulled my tank for repair, I siphoned it empty and removed the lines. Then instead of draining the float bowls, I thought I'd just run it..... I was surprised how long it took to burn through a bowl full of fuel.
I run some of this stuff called sea foam through my Monster every now and then. It's good as a stabilizer becuause it absorbs more water than other stabilizers and dosen't crystalize like some others. That can be bad for the FI.
1 - 10 of 10 Posts
