Jas, the Full Termi system Literally TRANSFORMS the bike!
It smooths the motor everywhere in the power band. Increases the rev limit by 500 RPM, and the sound @ 9K minus the DB killers is to die for!
It eliminates the ugly CAT/udder and the "S" pipes. This in turn gets rid of the pigeon toed right foot position when riding on the balls of your feet. [thumbsup]
The full system is a HUGE bump in HP & torque. for the money, and the RS will FLY with it installed and tweaked properly! >
Another positive of the full system is that with the CO levels tweaked to 3.9 the bikes low RPM manners are significantly improved. I've lugged the motor to as low as 1.75 in 6th gear, and under roll on throttle even though you can feel each power pulse it will still pull cleanly. Even with the extreemely tall Stock Gearing.
It doesn't surge or buck the way my stock piped S4R 996 Desmoquattro would under 4k. Even though both motors are happiest from 4k on up and I would not recommend lugging it that low on a regular basis, that's still a nice benefit around town or in extremely low traction scenarios.
Even if you must wait awhile to purchase the full 50mm system VS the slip-ons, DO IT!!!
THE GAINS ARE DEFINATELY WORTH THE WAIT AND THE EXPENCE! >
With stock gearing in 6th gear the bike will bury the speedometer just shy of the rev limiter. (I know this from first hand experience.)
Holding wide open throttle in any of the first three gears (Stock gearing mind you) will start to power wheelie at 7.5 with no input from the rider. 4th can easily be coaxed up as well. [thumbsup]
(You will honestly work harder at keeping the front wheel down and modulating the tire's slip-angle than anything else while riding aggressively @ 7.5K or higher. Very entertaining! [laugh] >
[thumbsup] )
Power and Torque are perfectly linear, and easily modulated. No power hits anywhere, just progressively building power right up to the rev limiter. [thumbsup]
You WILL love it, I PROMISE!!!
Good luck not riding like an absolute maniac once the full system is installed, its a VERY corrupting influence! >
<edit> LOL! Kind of Ironic that this is my 998th post, and we're talking about performance gains on the 998 Testastretta. >
