The Termi's are the slip ons. But the header is not. Did you make the header? Or did you buy a Cat Bypass from some place. By all the pieces of tubing sitting on the lift, I get the feeling you made the bypass. Are they connected with any kind of cross over? I here if the pipe lengths are not equal you will have all kinds engine proplems.
The work looks real clean. Where did you order the Termi's from?
Not to sound dumb, but why change the dual side exhaust? Is that a true S4R? I like the tank, is that all paint or carbon fiber sticker on the tank near the seat?
good looking setup, especially if you can crank the cans to follow the lines of the frame tubing under the seat. grunter... is a cross-over in the header's future? without one you're bound to loose a touch of power.
THIS SYSTEM IS BEING MADE , BUT THE GUY DID NOT LIKE THE LOOK SO NOW HE WANTS THEM UNDER SEAT?
CARBON TANK PAINTED OVER AND TAIL PIECE WE ARE WORKING ON REPLACING REAR PILLION PEGS WITH SOMETHING THAT CAN BE TAKEN ON AND OFF NEW PICS LATER TONIGHT
groovy... with a cross-over to help keep the power up, that's a pretty sharp looking system. if it were my own, i'd keep the cans out where they are (rather than under the seat).
I agree with strati. Except I would try to get them a bit higher. The Termi system like that is DP seems to hug the tail a bit closer. It looks real cool.
