Hi,
i have trouble removing my front cylinder spark plug. I tried with the underseat toolkit socket but did not work. I suspect the mechanic has installed a 18mm(11/16) instead of a 16mm (5/8). The toolkit contains a 5/8 socket.
does anybody has found a 16mm or 18mm commercial socket that can reach the plug without machining the socket ?
Discussion Starter #4
thanks guys,
i spoke with the mechanic who did the 10k maintenance. he put a 18mm plug so that leaves even less clearance around the plug. he told me to bring a 18mm deep socket (from the hardware store) and he will machine it for me. i had bought the Cruztools 5/8 16mm spark plug socket thinking the plug was a 16. That one should work for the 16mm plugs as its outer diameter is about 20-21 mm.
