All pics are with the forks fully compressed. Fork position in the triples is per Factory Service Manual specs, 195.5mm above the top of the lower triple!
(Oh yeah, I know my bike's dirty, so get over it. :
This pic shows the fender - radiator area. The fender is not just touching the radiator, it's pushing on the radiator. Scratching that pretty CF fender is one thing, but having the tire snag it and suck it through the forks is mayhem you don't need. Especially when you're pinching hard on the brakes and bottom the front end on a bump. Keep in mind that the forks and frame will be flexed back in that scenario, and there will be even less clearance....
A big warm thanks goes out to Ducati for designing an interference fit on moving parts....fu<kers.
This shows the fender to triple clearance, it's about 3/4" from the horn bracket 'beauty cover', and about 1" from the bottom of the triple itself.
