I already replaced one fuel sensor with a bare wire on the bottom of the sensor. Now the new one is squashed right up against the head. When I lifted the tank, you can see the rubber boot is all pressed down and will probably wear through from riding on the head.
Anybody else had this problem?
To make matters worse, it looks like the gas is seeping around the sensor again.
