1 - 8 of 8 Posts
Complete swing arm off a 2008 S2R1000 with 6500 miles on it. Includes rear axle, rear rotor, final drive, both axle nuts with spacers, and shock mounting bolt. I also have the original rear Sachs shock I will throw in if anyone wants it. The rear chain guard has some melted plastic from exhaust heat otherwise perfect condition. asking $600. All offers entertained.
I’m not sure. it might but I would that research before you make a decision. i know it fits the S4.
you also need the S2R rear swingarm pivot axle that goes through the engine of the bike. Not sure if they are interchangeable of the one on a M750.
Didn't you just sell your bike on ebay?
Discussion Starter #7
I had another swing arm powder coated to match the frame and then swapped out. The one for sale is the original.
The swing arm includes the rotor and I have the shock and ride height adjuster if you need. The only thing you would need is a rear caliper and a rear wheel. I have a set of OEM wheels from an S4RS also if you are interested.
Discussion Starter #8
I do not have the pivot axle and I also do not know if the one from your 750 will fit but I have seen them on eBay and other parts resellers.
1 - 8 of 8 Posts
