I just bought an '04 M1000 with no red key. It has the ds1000 engine, same as the s2r1k. Will the s2r1k electronics set work on the M1k? I figure I'll have to change the fuel pump, but that's not that big of a deal as I already have a poly monster tank. Might also need a new wiring harness, but I'll wait and see on that.
Edit*
Fuel injected and I am very capable @diy and troubleshooting.
Sent from my SM-G965U using Tapatalk
Ok, so I bought the clock/ecu/immobilizer/key/ignition set from an 06 s2r100 and installed on the 2004 m1000.
Started right up. Stock wiring harness, stock fuel pump and injectors.
