1 - 20 of 26 Posts
Hey guys,
I buried my 2002 750 after it was totaled from hitting gravel and laying it down and bought a 2007 S2R 1000 today. Holy **** that thing is scary fast, but now begins the fun part; upgrades. The 750 is going to be a parts gold mine; from it to the S2R I'll swap out:
Brembo Radial clutch grip, master, and slave
Fender eliminator with integrated brake light and turn signals
Ducati Comfort Seat
Short stalk turn signals up front
Starter motor wire (custom wire I created, routed under fuel tank instead of over the side of the bike
Crankcase breather vented out the back
CA Cycleworks coils, plug wires, etc
I was also thinking about doing the Speedymoto belt covers, but the S2R has sensors on its factory covers; what are these? Cant find anything online about them.
Don't think the seat is the same. Sensor? Sounds like a dual spark motor.
tt
Yeah you are right; dual spark cylinders. I was hoping to use my Speedymoto open belt covers and CA Cycleworks ignition coils from my seven fiddy but they wont fit. I really cant find anything that is an upgrade as far as aftermarket ignition coils go, but maybe ill leave the oem ones for now. That seat isnt the same? I'll have to look at that. Thanks for the info btw:grin
Discussion Starter #5
Nice - a s2r 1000! Is it a good step up or "too big"? Looking to upgrade from my 620 ;)
Nah, its the same size as my M750, the motor is obviously bigger but thats it. Its got a lot of ****ing power though, you will definitely notice it. I believe there is about 20-25 more horsepower than my seven fiddy, so be prepared. What years is your 620?
Discussion Starter #7
you have 60HP at the rear wheel on a 620? My M750 had 65HP at the rear wheel before I wrecked it, and that was after being dyno tuned with a custom map made for the cylinders. I have Termi exhaust on it and TPO Parts "beast" kit pod filters and velocity stacks too.
Discussion Starter #9
Jup, 60 at the rear stock.
I even have a full system Termi on it, dont know if that increased hp or not. It had it on when i bought it.
Did you get it dyno'd? Ducati measures the HP at the crank, so the numbers will differ. The factory measurement is 57HP for your bike (at the crank)
I'd be careful with the open belt covers. I had the same ones on my S2R for 3-4 years and they looked great. Coming home from work, I stop to let the garage door open and somehow the battery tender cable got tangled with the vertical cylinder pulley. Bent valves, messed up guides, etc.. I got it repaired and it runs great. I still kick myself for doing the mod. After the rebuild, I took the open belt covers and threw them in the trash...
Dave
Discussion Starter #12
Dave
I don't have open belt covers on this one; they were on my M750, but I'm not doing it on this one. I've had the same problem as you; Speedymoto open belt covers and a rag got sucked into the center crank sprocket once. Bent both intake valves and cost me $800 to get repaired. I'm going to get the Rizoma clear/windowed ones on the S2R.
Discussion Starter #14
Good luck finding them. Long discontinued.
I sold a used set a while back.
tt
Huh? They are all over the place. Just do a search for Rizoma Timing Belt covers S2R 1000
Discussion Starter #16
Yeah these are the 1000. These bikes are pretty similar though, except for the 200cc difference everything else is the same, yeah? You could take belt covers from my 750 and drill holes in the sides for the spark plugs,.
If the Rizoma clear belt cover are discontinued, look for the CNC racing one. Exactly the same design and slightly cheaper.
I've got them installed on my M1100S (dual spark as well) and with the open clutch cover, it's real bike porn.
Don't be surprised if you wind up missing the 750 in some ways. I love my M944 but man, my little 750 was such a fun little bike, very underrated motor and perfect for the street. Congrats on the S2R1k tho. Now you can power wheelie :p
Concur. This is why I still love the S2R800. Just right.
tt
Nope, motors are pretty much totally different from the case up. Heads are completely different. Make sure anything you buy will fit.
1 - 20 of 26 Posts
