1 - 11 of 11 Posts
I know this has been posted but i can't find it.
I am trying to upgrade my forks on my S2R 800. what size do they need to be? Diameter upper and lower triple? Can i buy Gxr fork legs and keep my triples? I am trying to do the simplest / cheapest swap for some adjustable forks. If you have any suggestions please let me know.
Thanks,
RB
You can also look in the FAQ section. This seems to be the deal : SBK have 53mm upper and lower bore on the triples. Monsters have 50 upper and 54 lower. You will need to bore the upper triple to 53mm and use a 0.5mm shim on the lower. Also make sure you get a fork with 65mm brake caliper spacing.
Don't forget Aprilia 1000 forks. They are the same Showas as the Duc SBK and they are black :eek:
Good luck.
1 - 11 of 11 Posts
