1 - 9 of 9 Posts
The gauges sweep, but then the immobilizer light flashes and temp read "LO" looks bazaar - with some extra lines.. also the time said 11:98 AM.. may be i got a time machine build in and didn't know it? lol.. anyway, please help, as i need to use the thing today ASAP.
thank you much!
Hmmmm.... That's odd for sure.
Here are a couple things to try:
1) Check to make sure you're kick-stand's up and/or your clutch is pulled in first. K.I.S.S.
2) Look to see if the low-amperage connector has backed out of the solenoid (2x smaller wires)
3) Disconnect the battery and wait about 30 seconds. Re-connect and try again.
I don't know if this will help or not...
Best of luck and have a Merry Christmas (despite your Duc's unwillingness to start!)
Try disconnecting and reconnecting the battery - then put a charger on it if you have one
That's what I would do - I have never seen this error before
Yeah looks to me like a low battery, sometimes electronics get a bit funny when they have a bit of voltage , but not enough.
+1 on the battery charge.
thanx.. no luck so far, it may be electronic issue.. will have to wait till tomorrow when the shops are open.
happy holidays
The topics from General and Tech are now merged. Please don't crosspost - thanks.
And good luck on figuring out your gremlin!
now this is a truly italian motorcycle.. it simply refused to work on xmas [clap]
started up today without a problem, however the numbers on cluster are still freaking out.
1 - 9 of 9 Posts
