Hi all,
I have recently purchased a late-2004 S2R 800 but since last week my rear brake light has stopped working when the key is in the 'ON' position. When the key is in 'Park' mode, the brake light works perfectly normal however. The other electric functions (e.g. claxon, hi-low beam etc.) are also functioning as expected.
I have tried to go through the wiring diagram but since I'm not an expert I find it difficult to digest and determine the problem. I did notice that when in 'ON', the rear light (NOT the brake light) seems to increase in brightness marginally (only noticeable if looking directly in the bulb) when I press either the brake lever or pedal.
Suggestions and/or solutions are greatly appreciated.
Thanks, Noud
