I want to install a damper on my bike which currently has 1.25" bar risers, due to physical ailments I'd like to maintain that height. I don't like the visual of the Ohlins side mount damper, I'd prefer a Matris, Scotts, or GPR setup.
Does Magura or anyone make a bar similar to the stock bend/sweep than has a 1-1.25" taller rise?
I installed the GenMar riser spacer and it helped my back immensely
Exactly, and the damper to protect the rest of my body - the bike is twitchy enough at times that I'd like a little umbrella policy. I haven't had it long enough to dial the sag, preload, compression, rebound, and ride height, but I've experienced hints of headshake and that's enough reason for this rider.
Bars would sure make it simple.
Discussion Starter #4
I think Multistrada 1100 bars (not the S model) may be the answer to my issue!
Any first hand knowledge out there?
