Re: running light conversion?
should honestly be very easy. you'll need to get dual-fillament signals and then just splice the "running light" wire for the signals in with the running light wire for the brakelight. the signal's wire should be labelled or just use either of the "hot" wires (as opposed to ground). to figure out which wire is used for the brakelight's running light, pop the seat off, turn the key on. the running light will be on, no? pull one of the hot-wires going to the brakelight and you'll find out which one's for the running light vs brakelight. splice accordingly.
