·okay so I am thinking of finally getting some
Braketech Axis iron rotors and pads, and Brembo radial pump...
a couple of question for you experts.....In trying to keep the wear down I was thinking something like Platinums would be fine, or should I go with CP911's?
Any reason I should consider changing my 2 pin Brembo's?
And which piston and offset to get? 19-20?
Anyone running the radial clutch pump?
Thanks in advance for the help......
