·i'm starting to shop around for rotors on my 900ss and am soliciting info on folk's good and bad comments on aftermarket rotors.
well, you can use 4 pad caliper on BT rotor, so that's not comparable.How do the OEM narrow band 998R rotors compare to the BrakeTechs using four pad calipers? Feel? Warping? Wear? Cost?
What my question meant to ask was to compare the rotors as if they were both using the same 4 pad calipers (I am currently running the 4 pads calipers with SinterGrip ST pads and SS OEM rotors).well, you can use 4 pad caliper on BT rotor, so that's not comparable.
