Yeah all you need is the same bolt pattern as your 620, which I believe the supersports have. Superbikes however will not work, and I think there may be differences with the newer S4R but I may be wrong there. Someone else will probably say too.
I'm 99% sure all of the 6-bolt carrier rotors are interchangeable.
At some point in the last couple years the SBKs went to 5-bolt.
S4Rs has the 5-bolt carriers, and I imagine the S4R Testastretta has 'em too.
Plain S4R has the 6-bolt rotors.
Except for rotors from any of the "R" Superbikes. (Ie: 748R, 996R,998R) Those have a different offset.
