I've got the none crazy dance around LED taillight bulb and it lights up very well. The only draw back I can think of is that no longer is the whole red lens lit up when I brake, but mostly just a bright red circle in the middle.
how did you get it to work!?Millertime said:I had one....
the Po-Po said it had to go!
Light up shoes were really bad ass back in the day. Everybody had those LA Gear.howley said:I think the cop had the right idea. Why don't you get some streamers and light up shoes to match?
as far as i can tell, it is seated properly. i fiddled around with the wires last night and was able to get it to blink - but not rotate or lightup at allpompetta said:The contacts are off-set. Make sure that you have them lined up correctly.
Sorry man, but I'm not much help. Those bulbs were plug-n-play for both my Bandit and my Monster. No re-wiring was required.MrFry said:as far as i can tell, it is seated properly. i fiddled around with the wires last night and was able to get it to blink - but not rotate or lightup at all
please tell me if i have it wired up correctly
