1 - 13 of 13 Posts
In the market for new reservoirs. Its still hard to believe Rizoma is the only brand out there making an alternative. I'm looking at the site - either Rizoma or another vendor's, and I'm trying to figure out which size is most appropriate.
Here's my application:
1999 M900 - Dual front discs, evoluzione clutch slave. I want matching (read: same size) Clutch and Front brake reservoirs. Now, I'm trying to figure out which size is the best fit. I have dimensions, and I'm almost to the point of making paper cut outs to visualize them.
I'm asking for pictures of these Rizoma Reservoirs - and the size you chose. (Also list any drawbacks, or what to do different).
The available sizes, according to the Rizoma Page are:
  • Vol. 26 cm3 - Height: 49mm - Dia: 40mm - Bottom Outflow
  • Vol. 27 cm3 - Height: 49mm - Dia: 40mm - Side Outflow
  • Vol. 35 cm3 - Height: 43mm - Dia: 50mm - Side Outflow
As much help as possible on this one would be great, I know others have been curious about the same issue. I would like to get this ordered by the end of the weekend.
- I love the DML -
Yeah, these are awesome. [thumbsup]
I'm looking to get these for my bike too! I want to have both reservoirs match in size. Always bothered me that one reservoir is smaller than the other one.
pompetta said:
Different size reservoirs for brake and clutch are unnecessary. Just purchase what you like. I have the smallest ones for both applications (and one for the rear brake too), and there's no problem. Just make checking the fluid levels part of your routine maintenance.
+1 I think Pompetta and I have the same set-up. Works well.
1 - 13 of 13 Posts
