REV'IT! Liquid Cooling Vest
$139.99 * FREE SHIPPING
REVIT Liquid Cooling Vest
The REVIT Liquid Cooling Vest is revolution in keeping you cool in the saddle. Everyone knows that when you overheat bad things happen and keeping yourself alert and functioning when traveling down the road on two wheels is paramount to preventing a crash. The Liquid Cooling Vest works by utilizing Hyperkewl technology, which works by absorbing and storing water, and then releasing it over time through the naturally cooling evaporative process, keeping you cool and in control. Designed specifically to be used with a highly ventilated or mesh jacket for maximum results, the vest will stay active for approximately 6 hours.
ERGONOMIC FEATURES:
Fit: Tour fit
Features: Easy entrance zipper at side torso
PROTECTION FEATURES:
Outer Shell: PWR| Stretch mesh, 4-way 3D stretch mesh
Lining: PU coated ripstop
Insulation:HyperKewl Polymer Embedded super absorption cooling fabric
Composition: 45% nylon, 11% elastane, 23% polyester, 21% viscose
REV'IT! Fluid Cooling Neck Collar
$34.99
The REVIT Fluid Neck Collar is an easy way to keep your cool. The unique Hyperkewl technology is activated by simply soaking the Fluid Neck Collar in water and provides cooling for up to 6 hours. By keeping the area around your neck cool, you can help reduce your body temperature and stay more alert when out there battling the heat.
Features:
Outer Shell:pWR| Stretch mesh
Lining: PU coated ribstop
Composition: 40% nylon, 10% elastane, 27% polyester, 23% viscose
* FREE continental USA shipping on orders over $100.
* Outside continental USA, use shipping passwords:
GLOBAL250 gets 25% off shipping on orders over $250
GLOBAL500 gets 50% off shipping on orders over $500
GLOBAL750 gets 75% off shipping on orders over $750
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items or upgrade to VIP passwords for the deepest discounts on all items. Look for memberships and choose the membership type that fits you the best
