As everyone has said you basically need to replace anything rubber, especically timing belts and tires. they could save serious expense immediatly the other will just make things go smoother and avoid breakdowns in the shortterm, like the first time you get a 100 miles from home and the little rubber bits in you carbls that held up for a bit crapped out on you later. Handgirps while your at it....
You have a handle on the brakes it seems like, one caliber is new but did you check the other to make sure it is ok? SImple thing to do and probalby worth doing a rebuild on it even if nothing is apparently wrong with it. Same on rear
Forks, they are pitted. Get some of those(can't think of name) green pads that will not scratch your forklegs and put some light lubricant on them and gently clean off your legs. YOu might get lucky and have caught it in time :
Ohterwise you will know it when your forks start leaking..... If they do not leak then firt opportunity spend the bucks to have your forks serviced with new oils seals wipers and valved/sprung to your weight. If they do start looking for a new set. PULL THE REFLECTORS OFF
FLUIDS, brakes, hydraulic, oil, gas. PUll the tank off while doing your carbs and rinse it our SEVERAL TIMES. pouring the washed out stuff into a container that you can inspect. If it is coiming out dirty put some nuts, not nuts like squirrels like, the ones like hod your bike together, in the tank ans swish the gas/nuts around until you are tired sot prest repeat, drain inspect drain inspect, repeat until clean. If that doesn't work then you are going to have to find out about this other stuff, I think it cleans and possibly seals up rusty old tanks.
CHAIN SPROCKETS INspect them carefully, treat to a new set if you can, get a nice new gold bling chain, they are also higher quality.
Alternatively if the sprockets are ok then pull the chain off and give it a good cleaning and lubing. With the CHAIN OFF you can tell if any of the links are stiff. Cant really tell if on the bike and is usually not an issue unless some sado masochist has let his bike sit for 6 years.
CARBURETORS> Pull them and rebuild them with all new rubber parts, jets don't cost much either, I'd just replace with new brass, especiealy if the bike had 25K miles plus. At a minimium pull and give a good cleaning. New brass can save you a lot of troubleshooting later.
CABLES are fairly easy and cheap to replace and give a nice new feel to the bike. Otherwise get a good cable luber and lube all
ELECTRICAL, While you have your tank off and seat fairing take several hours just going through connections and pulling them apart, clean if necessary, add a drop of 3in1 oil or similar and reconnect. when reconnected give the wires a pull test, move on to next connection. Tag all connectors with tape when you do one so you know you got all of them.
SEAT might crack real soon (PLASTIC RUBBER thing) like as soon as you start riding it again. There are several upgrade seats or you might find someon who has upgraded and want so sell there stocker.
Shame on you for letting it sit for that long and same for not getting on this during the winter.
Get her going and post pics and we will forgive [thumbsup]
