What si the safest way to remove throttle grips? I was planning to just cut it off but how do you install the new pair?
Also, I noticed that on the old pair there are grooves to fit the plastic portion of the throttle, and the new grips don't have them. Can I install the new grips anyway?
I use hair spray to put my grips on. It works really well, it lubes them and make them stick when it dries. I also just cut my old grips off.
Wow, never thought of hairspray!!
Discussion Starter #4
You don't need to cut the old ones off.
Stick a small thin screwdriver under neath the grip and spray windex under the grip. It will slide right off.
