Replacing my rear sprocket...what type of issues will i have with the remount?
530 Views 5 Replies 2 Participants Last post by  hiero
I got a gearing report from the gearing guru and will be replacing my rear stock 42 with a 44. Besides a new chain and of course adjusting the slack, is there any other type of adjustment i need to be aware of? lateral?
thanks
what kind of bike is this?
what is the condition of the front sprocket? hoe many miles on it? usually you want to replace all three at the same time.
all three should generally be replaced together, unless the front literally just has a thousand miles on it.
a worn sprocket (front or rear) will accelerate wear on a new chain, because the modified profile of the teeth will not match the pitch of the new chain (only the worn chain).
so, how many miles are on the front sprocket?
oh yeah, with an SSS bike you dont need to worry about chain alignment, just tension.
no prob.
get one of those cheap 14T's from chris at ca-cycleworks. i hear their quality is just as good as the DP part.
Ash said:
no prob.
yeah, the JT sprocket's not bad at all
