How does one do this? It's not in the "how-to" list so I thought I'd ask here.
I see a couple of nuts that have to be removed. But where the blinkers are attached it seems the windscreen is also attached there and I don't know how to take the blinkers off. Or maybe I don't have to?
no you don't have to. don't know what bike you have (??) but on mine it was a simple matter of removing 2 bolts. didn't have to move anything to get at them. had it off in about 5 minutes.
Okay I got it off. I had to remove the bolts for the instrument panel and push that aside to get at the bolts for the windscreen. Once the bolts were off I had to pull at the screen to get the tabs to slide out of the rubber wedge that they are in. Then the screen came free. These rubber wedges are in place by a bolt that also holds the blinkers in place, that's why it looked like I had to remove the blinkers to get the windscreen off.
