I have my bike hanging from the door frame chin-up bar.
How did it get there? :
Well, I have been trying to install a SIL MOTOR high exhaust. Now I need a step by step on how to reinstall my ride height adjustment bar. I would think twice about buying one of these exhausts. It took about 4 months to get and nothing fits. True my mechanical skill level is a sledge hammer, pry bar and an axe. If it takes more than that there is going to be a whole lot of @#$*! and the wife goes shopping for the day. One end of the pipe had a flat spot so two peices did not fit. Fixed that, then The front header does not line up with the bolt holes. It is about a half a bolt width off. the rear header is too long it sticks out too far before turning down and hits the ride height adjustment bar. I thought if I removed it the pipe might fit (not even with two sledge hammers ;D) so now I can't get the ride height bar back in place. Even with no pipe in the way. Any tricks tips or direction on how to get it the ride height bar to fit abck in its original configuration is greatly appreciated and desperately need.
While its apart I might as well finish taking it apart and get the swingarm powdercoated. If the bike is suspended are any parts under pressure? The bottom bolt going through the shock and bottom of the ride height bar is like welded in there.
Thanks.
