Are the bar end caps on the 620 threaded or do you need to use a screw driver the prey them off?
G Guest · Discussion Starter · #1 · Sep 20, 2003 Are the bar end caps on the 620 threaded or do you need to use a screw driver the prey them off?
T test-reg · Registered Joined Jun 16, 2003 · 51,206 Posts #2 · Sep 20, 2003 Only show this user they pull out. grab 'em with pliers and twist.
